Front fork upgrade
Old Nov 9, 2022 | 02:29 PM
3bikes1will's Avatar
Default Front fork upgrade
Hi guys are there any options to upgrade front forks from these air ones? I think I've overinflated mine and according to the manual that means I've probably broken them, rather than faffing about with these can I get something modern? If I'm not mistaken they're an odd size?
Any advice is appreciated, I'm an engineering student so if I need to have some bits made that's no biggie but I have no clue about bikes.
Old Nov 9, 2022 | 06:28 PM
dannoxyz's Avatar
Install the RaceTech gold-valve emulators.
Old Nov 15, 2022 | 03:15 PM
stanthomas's Avatar
The worst you will have done is blown the seals (there's an old joke in there ). Quick, cheap and easy to fix.
You can change the forks to a later CBR600 but you need a complete front-end including yokes (american: triple-tree), wheel, axle, brakes, discs, handlebars. Doable but a lot of trouble unless you have a donor bike. IMO the original forks are good enough and I wouldn't bother changing them unless yours are damaged or badly worn. And even then I'd probably try to find some good used ones from a breaker. As they say, if you want an RR, buy an RR (they are bloody brilliant ).
Henkies
Feb 4, 2018 02:31 PM
alienjoe
Aug 26, 2013 05:50 AM
lloydiecbr
Apr 14, 2011 05:53 PM
Dragit86
Jan 26, 2010 07:52 AM
goldenboy929
Apr 7, 2008 05:18 PM
