Best Fork, RSU/conventional
Old Feb 4, 2018 | 01:07 PM
Henkies's Avatar
Default Best Fork, RSU/conventional
Hi,
I'm investigating a possible fork upgrade for my '77 CB750, with conventional forks.
Triple tree has to be custom to get the right offset, so I could use any legs. The bike has about 80HP, wet weight is approx 230kg/505lbs, with rider around 305kg/670lbs. I prefer max 41mm diameter for the looks, bigger doesn't really match that age.
What are the best sport forks then? Thanks!
Old Feb 4, 2018 | 01:38 PM
CaBaRet's Avatar
Here are just some of the fork sizes 41mm
File Type: pdf
Old Feb 4, 2018 | 01:46 PM
Henkies's Avatar
Do you have it for 39mm as well?
Old Feb 4, 2018 | 01:59 PM
CaBaRet's Avatar
Here ,but not as many
File Type: pdf
Old Feb 4, 2018 | 02:31 PM
Henkies's Avatar
Ok thanks. There are younger 41mm sport forks as well, or otherwise I have to consider 43mm.
estate4life
Mar 16, 2012 12:09 PM
deegaw11
Sep 1, 2011 01:29 AM
STL TRPN RR
Dec 15, 2008 01:06 AM
Camelio
Jul 21, 2008 12:41 AM
98f3pilot
Mar 24, 2007 09:06 PM
