Fan Replacement Difficulty Question
Old May 30, 2021 | 10:38 AM
Beekeeper's Avatar
Default Fan Replacement Difficulty Question
Hi,
At a recent service, the shop found that my other half's CBR600FK fan had packed up and confirmed it was the fan, not the switch. I've now sourced a working second hand fan. How big a job is it to replace the fan? I've checked the Haynes manual, but it's not really clear. Has anyone done this please and can advise on time to set aside. I service and build classic Italian bikes, so all tools and stuff are to hand.
Thanks in anticipation.
Old May 30, 2021 | 10:57 AM
I haven't worked on your specific model but in general it's an easy task. You may/may not need to loosen or remove the radiator bolts to gain enough clearance. You stated that you build bikes so it really should be pretty breezy for you.
Old May 30, 2021 | 12:11 PM
A couple of hours should do it, you will probably take longer removing the fairings than replacing the fan, the only issue could be seized bolts on the fan itself.
kdub41
Jul 10, 2008 10:45 PM
bakesf4i
May 23, 2008 11:52 AM
98f3pilot
Apr 7, 2007 06:25 AM
natlbnldr
May 30, 2006 12:15 AM
F4i_nsane
Feb 23, 2006 01:54 AM
