fabricating rear peg set
hey guys, i want to fabricate a set of brackets for the rear pegs
since i cant afford to buy a pair, i planed on making a write up or document it at least.
anyway can someone can measure the length of each bar of the peg bracket for me?
from center of bolt hole to center of peg each bar, and about how far it it bent out, thanks
anyway since no ones responding i guess im just gonna wing it, i got some 1/2 inch hollow steel tubing and cut then down to size @ 10 10 12 and 14, giving a little extra length just in case, the 14 is extra long so it can hold the can, going to be taking 2 at a time, the matching 2 for each side, sticking the ends in a vise and heating the point im bending up with a torch , then just bending by hand, making a bend at each end. and then possably on of the pipes i will bend sidways after the 2nd bend to match the pitch of the other tube, then just drill out and bolt togather, ill be posting pics of all this if anyone else wants to try it
romanboy
01-06-2013 08:57 PM
berga
F2 Tech
03-25-2010 10:11 PM
