upper shock bolt removal???
Old Jun 4, 2012 | 04:49 PM
dorky_dude_559's Avatar
Default upper shock bolt removal???
well my rear shock needs to come off to get rebuilt, and the upper shock bolt seems like it's an inch too long to come out.
Old Jun 16, 2012 | 05:56 AM
inlove2marrow's Avatar
New Member
you have to take the wing arm off , it is a pain in the a s s to take the spring out but i guess you dont have a choice the only way is to take the rear swing arm off , this should to take you about 2 hours , good luck , and it will require a large selection of sockets to
Old Jun 18, 2012 | 11:10 PM
TahoeRider's Avatar
No you don't. The swing arm does not have anything to do with the upper shock bolt.
It will clear the frame once you have the bottom of the shock loose and tilt the shock to the side. Make sure the bike is supported with the rear wheel off the ground.
dodger79
Oct 29, 2012 06:45 PM
__Z__
Jul 23, 2010 08:15 PM
dafizuck
F2 Tech
May 18, 2010 12:56 AM
ocf4
CBR Zone
Oct 27, 2009 10:33 PM
Jaybird180
Feb 15, 2007 02:06 PM
