F3 transformation....
did you clean and lube the caliper slider pins? make sure the caliper isn't binding.
might tryworking the brake without it over the disc. exptend the pistons out, and re seat with a C-clamp a few times to work everything loose. also, make sure the brakes are bled very thoroughly. any air trapped in the system will cause the pads not to release all the way.
