Engine vibration...?
Old Mar 31, 2009 | 10:55 PM
WildWill's Avatar
Default Engine vibration...?
At higher RPM while running I am getting a engine vibration. I know it is comming from the engine because when i pull in the clutch it goes away. Could i need to rebuild the clutch (bad springs?) Also where can i get a clutch rebuild kit cheap?
Old Apr 1, 2009 | 01:24 PM
michigan_313's Avatar
depends, at what rpm range are you experiencing this vibration? depending on what range, it could be normal. If you increase rpms, does vibration go away or decrease? if you decrease rpms, does vibration decrease or go away?
Old Apr 1, 2009 | 04:40 PM
Five's Avatar
I wouldn't jump to the conclusion that it's an engine problem. If the vibrstion disappears when the clutch is disengaged, I would look at the transmission.
Old Apr 1, 2009 | 05:28 PM
hypeshipe's Avatar
check your mounts
johnwdavis23
Jul 5, 2011 08:03 PM
cbrmeasap
Aug 18, 2009 06:48 PM
Timidfriendly
Mar 8, 2009 02:26 PM
Stargazer
Sep 4, 2007 09:01 AM
vortex1114
Sep 28, 2006 11:09 AM
