At higher RPM while running I am getting a engine vibration. I know it is comming from the engine because when i pull in the clutch it goes away. Could i need to rebuild the clutch (bad springs?) Also where can i get a clutch rebuild kit cheap?
depends, at what rpm range are you experiencing this vibration? depending on what range, it could be normal. If you increase rpms, does vibration go away or decrease? if you decrease rpms, does vibration decrease or go away?
I wouldn't jump to the conclusion that it's an engine problem. If the vibrstion disappears when the clutch is disengaged, I would look at the transmission.
