Counter shaft seal
Old May 25, 2025 | 08:31 AM
heresolong's Avatar
Default Counter shaft seal
I can not, for the life of me, find the counter shaft or seal in any parts diagram. I'm used to looking at Harley diagrams and it seems like this should be easy. It doesn't show under crankcase, shifter, left rear cover, nothing. I've looked at every diagram, including some that would make no sense. I can't even find one that shows the front sprocket. Can someone either point me at the correct diagram or give me a part number for the seal? I've got a bit of a leak on the '88.
Thanks.
Old May 25, 2025 | 08:38 AM
heresolong's Avatar
Turns out all I had to do was post here in order to suddenly find it. On the "Transmission" page, which makes perfect sense. 😁
I love that they even give you dimensions, which Harley never did. I have a list of Harley sizes that I've compiled over the years ($2 drain plug o-ring that is $.13 if you buy a bag of 100 from McMaster-Carr, really?) but they keep that stuff super secret.
Anyone know if I can just go buy a seal of the right dimensions and slap it in? I'm a mechanic so if it doesn't last as long as the original, no big deal, I'd just put another one in.
Old May 26, 2025 | 02:43 AM
Ed Harris's Avatar
I’ve done it with several of the bearing seals on my 93 with no problems - as long as you have the od, id and thickness and buy a reputable make I see no reason not to.
Nos4r2
Apr 15, 2021 07:36 PM
Johnny34
F2 Tech
Jan 25, 2014 05:22 PM
tomttt
Aug 18, 2012 05:57 AM
jam0837
Jan 23, 2009 05:52 PM
bond67
Apr 11, 2008 12:05 PM
