coolant tank
Old Mar 12, 2007 | 10:34 PM
buff_bills1983's Avatar
Default coolant tank
i have a 88 cbr and cant see the fluid level on the tank. i think it is full but is there another way to tell the level. thank you
Old Mar 13, 2007 | 12:43 PM
rrasco's Avatar
Default RE: coolant tank
i have a hard time telling too, i always think its empty, put water in it and it overflows.....i think thats just about it.
Old Mar 13, 2007 | 03:31 PM
michigan_313's Avatar
if you have regular coolant in the tank and shine a flashlight to the side, you should see the green tinge. that will tell you how far the coolant level is. or if you are using water, hopefully deionized, you can add food coloring, something dark and that will tell you how far the coolant level is. if you use food coloring, make sure it won't stain the plastic and all you need is a couple drops or enough to turn the coolant dark enough to see.
F4Mike
Nov 11, 2010 09:52 PM
smr96
Mar 4, 2010 10:16 PM
oliversta
Feb 24, 2006 08:55 PM
oliversta
Feb 15, 2006 09:48 AM
oliversta
Feb 14, 2006 10:50 PM
