Clutch questions
So ive been trying to learn clutch ups recently. the clutch has been going anyway, i figured it was a nice was to kill it ![Wink](https://cbrforum.com/forum/images/smilies/wink.gif)
well today i went to do one and it slipped instead of popping the front up as usual![Frown](https://cbrforum.com/forum/images/smilies/frown.gif)
finially died!
so what do i need to order?
bike clutches are a bit different vs car clutched which im familiar with
a car i just grab a new disc and resurface the PP and FW.
how do i do a clutch on the bike?
finially died!
Start by picking up a new gasket for the clutch cover, springs and a new lock washer. I just pulled my clutch out and all the plates were within spec...just the springs were weak. It is a good place to start. If the plates are too thin they will need to be replaced...and nobody sells a kit that I've found. The plates have to be ordered individually through Honda.
you need a micrometer most importantly. stunting a hurricane is stupid if you ask me, I'd rather see an F4i stunted.
but that isnt what yo uasked. you'll need a micrometer and manual to measure specs on your frictions, springs and steels. anything out of spec, replace. even if its just one. period
new springs is 99% of the time a must. get the cover gasket too, you'll need it. mine has never had to come off, and I WANT to keep it that way.
im not really stuunting it stunting it. just learning some wheelies on a cheap bike. its naked and cost 500$
id rather try to not drop this so if/when i get a nice bike i can do an occasional wheelie without worrying TOO much about dropping it. i dont think im looking into hardcore stunting :P
i have the PDF manual i suppose i should have looked there to see!
ill probably pull it all apart here in the next few days and begin looking around
this is my first wet clutch setup
all I can say is stunting is stunting. even casual wheelies are stunting. its tough on all sorts of components, and dropping is a part of learning the trick.
hence why I have a DR650 in my garage. eventually, it'd ROCK to have a WR250 for stunts... geared with a cage and 12bar.... yeah, I'm nuts.
but back on track. odds are more than likely springs DO need replaced, 99% of the time I check them and they're the biggest issue with any bike I look at where the owner cmplains of a slipping clutch. or they adjust the cable wrong and it has no freeplay.
