choke not working
Old Jun 7, 2009 | 01:14 AM
tony2things's Avatar
Default choke not working
when i open the choke all the way . it dosent throttle up right away or increase when opening .
Old Jun 7, 2009 | 06:49 PM
KongBastard's Avatar
I would check that the cable hasn't broken. See if you can see the choke arm moving or the valve assembly moving when you move the choke lever. If you look in the manual you can see how it all goes together.
KongBastard
Old Jun 7, 2009 | 07:04 PM
camoweasel's Avatar
it also possible that the choke cable has slid or come free from the little bracket where it bolts to the top of the carbs. If that little screw came loose, then the cable won't operate right.
Old Jun 7, 2009 | 08:34 PM
i checked the arm and cable and there both working
Old Jun 8, 2009 | 02:07 PM
tripicana's Avatar
sometimes, ill have to rev my bike a little to get it to hold a higher rpm with the choke on.
check to make sure the chokes on each carb are actualy opening. that arm is connected to a rod. each carb is connected to the rod with a set screw. if the screws are loose, the whole rod and arm can move normaly without actualy opening the chokes.
how does it run otherwise? time for a carb cleaning?
Old Jun 8, 2009 | 03:16 PM
rrasco's Avatar
i had to tap small threaded holes and put a screw to keep my rod working properly. it wasnt engaging the choke on each carb without them, it did just as you speak of.
Spartan86
Aug 14, 2013 12:55 PM
ian1001
Apr 19, 2012 11:19 AM
Pabs85
Feb 27, 2012 03:26 PM
quadracer18
Jun 6, 2010 02:46 PM
aadoublea
Aug 18, 2008 10:16 PM
