choke not working
sometimes, ill have to rev my bike a little to get it to hold a higher rpm with the choke on.
check to make sure the chokes on each carb are actualy opening. that arm is connected to a rod. each carb is connected to the rod with a set screw. if the screws are loose, the whole rod and arm can move normaly without actualy opening the chokes.
how does it run otherwise? time for a carb cleaning?
