Carb Question
Ok guys, heres the deal. I broke off a siezed pilot screw, so i had to buy a used set of carbs and build a good set for the bike using carbs from both sets. Got it all back together, and now its idling at 4000 rpm. Could being out of sync cause this?
ok found out what 1 part of the problem was, 1 of the throttle plates was screwey, wouldnt shut all the way. swapped it aout with another and it dropped the idle down to 1500rpm, I think with a decent sync it should be good to go.
