Brakes?
Old Apr 15, 2008 | 09:23 AM
99offroadrngr's Avatar
Default Brakes?
what do people recommend for brakes? (both front and rear) and approximately what is the cost?
I am in need of replacing brakes on the bike i just got because they are horrible.
Old Apr 15, 2008 | 01:13 PM
michigan_313's Avatar
Default RE: Brakes?
i use ebc pads and rotors. if just pads, they run around $30/side and $20some for the rear for HH (sintered). Organics will be cheaper.
if rotors, $110-$120/disc. the rear rotor i don't know, haven't had to change it yet.
i've also used galfer pads, also HH. they are a couple dollars cheaper.
Old Apr 15, 2008 | 05:52 PM
Default RE: Brakes?
will the sinisters go with OEM rotors? because i know that if the stock brake pad is not sinister the replacement should not be sinister either and would need a ceramic pad.
Any idea?
Old Apr 15, 2008 | 07:34 PM
Default RE: Brakes?
sinister? evil?
when i was using oem rotors, i had used a sanding pad and hand sanded both sides of the rotor to de-glaze the surface. i know what you mean about the oem pads. you can just use organics or whatever is closest to oem pads, but if you are looking for increased stopping power, get sintered, not evil. however, sinister pads sound kick-***. if you get a set, let me know how they work out.
Old Apr 17, 2008 | 12:56 PM
HurricaneRider's Avatar
Default RE: Brakes?
What is a good sign that you can tell you need to replace the rotors?
Old Apr 17, 2008 | 06:08 PM
Default RE: Brakes?
if the rotors have score marks on them or warped. but ifthey look alright then you will have to get a caliper to measure the thickness. the min. thickness is stamped on the disc. take measurements from the lowest spots on the rotor. you can also tell from if the edge of the rotor is higher than the braking surface after it. like if you run your finger from inside out and you feel a high lip then you may need to change them, but the best way is to measure.
Old Apr 17, 2008 | 08:28 PM
Default RE: Brakes?
Ok thanks alot!!!!!
Nytmr
Dec 21, 2013 09:16 PM
CBRInfantry
Feb 7, 2011 09:42 PM
hopz
Jun 4, 2009 01:28 AM
radvoem
Dec 28, 2008 08:38 AM
