Bike Died while doing 45mph??????Update!
Old Apr 15, 2008 | 03:35 PM
HurricaneRider's Avatar
Default Bike Died while doing 45mph??????Update!
I was out cruising today through some widy roads, when all of a sudden my bike started boggin down and then letting off, for a few seconds then straight died. I put the clutch in tried to get it to fire, no response what so ever from the start button(full battery). I called the mechanic i know and he thinks it could be a stator or a short, or something else hes not positive so i dont like his opinion so what do you all think, need to know asap!!!!
Old Apr 15, 2008 | 05:28 PM
michigan_313's Avatar
Default RE: Bike Died while doing 45mph??????
my first guess would be rectifier/regulator. next would be CDI. and 3rd would be a short. stators don't usually go bad but it could be a possiblity.
i would check the main fuse (30A). check your wire loom for any frays, shorts, burn marks, loose connections, etc.
the clue here is no starter response. check that circuit wiring andcheck the fuse.
Old Apr 15, 2008 | 06:15 PM
ORIGINAL: michigan_313
the clue here is no starter response. check that circuit wiring and check the fuse.
The bikes been sitting for about 4 hrs now, and i tried to start it out of no where, when i pushed the starter button it makes a faint buzzing noise now from the motor.
Old Apr 15, 2008 | 07:38 PM
now it sounds like you have 2 problems.
1. bike dies out while riding
2. cannot start bike afterwards.
so...now the starter motor makes a faint noise. could be your starter is going. or check the amount of juice going to the starter terminals. get a meter and see what you get. also, check the starter relay. maybe it's not passing enough juice to the starter motor.
until you get that figured out, i don't think it will be easy to diagnose your flame-out without the bike at least running.
Old Apr 15, 2008 | 08:26 PM
Ok charged the battery again and fired it up. Started strong, took it for a spin, died after about 4 miles of riding, lights all still on the dash & headlight, but no response from the starter. Could it be something sucking the **** out of the battery(short i hope not), or is the battery toast(only 2 months old gel battery).
voltage 12.4 running, turn off let it sit half hour fired right up 12.4, does the battery need to be charged every once and a while? or is it the r/r?
Old Apr 15, 2008 | 10:10 PM
89cane's Avatar
i think when runningthe battery should be at 13 or higher and when revving to about 5k it should be around 14 not higher though or its a bad r/r
Old Apr 15, 2008 | 10:30 PM
the charging system on the bike should be charging the battery.
download a copy of the manual and follow the instructions on how the check for an undercharged battery.
i stick with my first guess, the r/r. next would be a short or loose connection.
Old Apr 16, 2008 | 09:20 AM
I was wrong its 13.4 not 12.4 i checked it again this morning.
Old Apr 18, 2008 | 09:32 AM
Ok so i charged the bike over night. Fired it up took it for a 25 miles cruise, came home turn it off, and then out of curiosity i tried to turn it back on, very weak starter sounds.
Ok heres my specs on the system today
sitting after charge
12.4
Running 13.4 - It was charging, and then shut the bike off. Then fired it back up and it didnt charge(check charging system)
Ok i checked the wires for the R/R came out 12.4 sitting same as battery
I checked the Alternator wire came out to be 0.5-0.7 was bouncing back and forth between those numbers.
What else is there to check if the R/R and alternator/stator check out ok whats next a short somewhere or CDI?
bluedevil3758
Jun 23, 2010 10:45 AM
mump420
May 19, 2009 09:53 PM
samill42
Mar 26, 2008 02:00 PM
markcbr1100xx
Sep 24, 2006 11:40 PM
CBRCorey
Apr 18, 2006 03:45 AM
