???87 hurricane help???
Old Jan 31, 2011 | 05:09 AM
The-wrench's Avatar
Default ???87 hurricane help???
Ok guys im super new here so bare with me, "Hope i'm doin this correct"
I have a 87 cbr 600, a gift, been sittin for a few years with no love, got a goog crank but now spark and no fuel, jumped fuel pump and it works good, very good pressure and all, im stuck, im a mechanic by day job but really dunno much about this here, any tips or knowledge would be awesome, i really want to revamp or restore this but dont want to get to far or spend moneys i dont need to, if i get it runnin id love to keep you all posted with pics and updates as i go, seein here you guys know your stuff about these and seems there a good stout lil bike, sooooooo PLEASE HELP MY NON KNOWIN CBR REAREND.
Thanks Micah Sr......aka The Wrench....
Old Jan 31, 2011 | 06:42 AM
boostdog's Avatar
get a repair manual / get your tools out and have at it. rinse and repeat
Old Jan 31, 2011 | 03:25 PM
shakey's Avatar
If it's been stood for a while, I'd start with putting fresh fuel in and then checking for bad electrical connections. Specifically the block connectors to the CDi unit and ignition switch if you're not getting a spark.
Old Jan 31, 2011 | 06:08 PM
Billistic's Avatar
Check the 10A fuse at the fuse block located under the small fairing panel next to the left fork/ clip on.
It powers all of the above mentioned things.
It helps when you post to add more info such as I have/ do not have power anywhere else. I assume lights come on when screwdriver turned? Engine turns over?
Old Jan 31, 2011 | 06:17 PM
thrasher572's Avatar
>>>couple of things. The pump is not intended to run all the time. Make sure you have a properly charged battery. Low voltage can cause glitches that disappear with a fresh battery.
hurricanematt
Aug 9, 2019 12:21 PM
cal_look_zero
Jun 15, 2012 09:34 AM
Saldo1981
Jan 2, 2009 08:43 PM
ebinz88cane
Apr 25, 2008 06:05 PM
BostonCBR600
Mar 15, 2007 10:44 PM
