1990 CBR 600F
Old Sep 20, 2008 | 06:44 PM
Darrylthenewf's Avatar
Default 1990 CBR 600F
Not getting any power to the starter. I turn the key on and the horn and signal lights work. But when I press the starter button nothing. Starting doing some small checks that I know and no spark either when I cross over the solenoid. The starter turns excellent.
Anybody ever come across this problem?
Thanks in advance......
Old Sep 20, 2008 | 08:05 PM
Hurricane rider's Avatar
Default RE: 1990 CBR 600F
I just had the exact same issue, and it was because my starter button's internals broke. if this is the case, you have to track down a new starter button assembly, or buy one online. Bikebandit still shows the part available, but its $90.
Old Sep 22, 2008 | 11:12 PM
Billistic's Avatar
Try this...
Check the 30A fuse ( in starter relay ) and all the 10A fuses on the fuse panel. The oil pressure and neutral switches have individual bullet connectors (under the gas tank as well) on the right side of the R/R connectors.
Order of components is as follows...
1. Battery
2. 30A fuse in starter relay
3. Ignition switch
4. 10A fuse ' G'
5. starter switch
6. starter relay coil
7. clutch switch then ground OR diode then neutral switch then ground
Old Sep 23, 2008 | 08:21 PM
Thanks for the responses I will check it all out.
A friend did the engine over last fall and he said he started it no prob. I put her away then Christmas time and tried to start her in July. I am kinda thinking it is the starter button.
Old Sep 23, 2008 | 08:56 PM
If it IS the starter button, buy a NEW one, rather than chancing a used one. I bought a used one, but I'm never positive if it'll work or not, since ebay is like that.
Bikebandit carries thhe starter button assembly, without the whole cluster for $90 before shipping, I'd imagine ronayers, servicehonda, or some similar site may have it cheaper.
suavegav
Apr 15, 2013 05:07 PM
44Gilly
Mar 15, 2007 05:42 PM
claffy
Jul 19, 2006 01:51 AM
