1987 honda hurricane 600 wont turn over
make sure the spark plugs are out and the killswitch is in the off position (if it is on the spark plugs have a chance to ignite the gasoline if they are accidently grounded) and let the engine crank... all the gas should come out, quite violently
my suggestion would be to double check that starter relay located beside the battery on the left side of the bike. mine is broken right now and everything turns on but wont turn over. when i jumped the starter relay it started and then the low beam light also came on so good luck.
Finally decided to work on it after not finding the problem so last Saturday decided to work on it a bit more bought a cdi box and still didn't want to do anything come to find out it was the starter selinoid! Thank you all for all the help much appreciate it! Another question I have an issue with my head light, brake light when I hit the brakes and left turn signal doesn't work but when the bike is on the high beam the back brakes and right signal work what can cause this? She sounds amazing!
adam 88 can u tell me how the starter seloniold goes connected i know positive wire to the left and negative goesmto the right and theres 4 wires that also goes connected to the seloniod idk if they r wired up right or not thank u
