CBR 1100XX "Super Blackbird" 1998 - 2003 CBR 1000XX
front sprocket
Old Apr 21, 2018 | 09:34 AM
Brendon Zammit's Avatar
Default front sprocket
Guys,
Is it normal for the front sprocket to be slightly wobbley with abit of play?
We're talking a milimetre of play. Would like to put my mind at rest.
Thanks for your feedback Brendon
Old May 10, 2018 | 09:40 AM
TimBucTwo's Avatar
Yes very normal. I have had some that were very wobbly on different bikes.
Old Jul 11, 2018 | 11:35 AM
KenG's Avatar
Senior Member & can cook minute rice in 58sec
iv seen bikes with no bolt or circlip, and run a long time without issue.
a wobble is fine.
Old Jan 1, 2019 | 09:42 AM
Commander_Chaos's Avatar
Is the sprocket moving on the shaft, or are they moving as a unit? The sprocket moving on the shaft is NOT okay and needs to be secured.
The entire shaft/sprocket assembly moving as a unit is normal within limits. Rotational movement is normal drivetrain lash that becomes greater as the gears wear. Side-to-side movement (endplay) is also normal. Neither is likely to be a problem until the gearbox is totally trashed, and by then you'll likely be experiencing bigger problems.
ebinz88cane
Feb 19, 2010 08:58 PM
DBEAU
Jul 2, 2008 01:23 PM
rgs
May 15, 2008 11:25 PM
mxtrails
May 15, 2008 05:03 PM
younghutch
Sep 3, 2007 11:08 AM
