CBR 1100XX "Super Blackbird" 1998 - 2003 CBR 1000XX
97 CBR 1100XX HELP PLEASE
Old Sep 8, 2008 | 03:26 PM
cbr 1100xxx's Avatar
Default 97 CBR 1100XX HELP PLEASE
OK HERE'S the problem i was just crusing and my speedo went from 55 to 0 back up to 55 and so forth... it does it some times and sometimes not. i check the speed sensor seem ok. the rectifier / regulator is putting out a 116 degree reading on my temp gun. is this what the problem is?its driving me nuts please help... thanx alot
Old Oct 12, 2008 | 06:45 PM
fasthigh28645's Avatar
Default RE: 97 CBR 1100XX HELP PLEASE
Its time for a new speedo cable
Old Oct 14, 2008 | 06:30 AM
Dean0's Avatar
ORIGINAL: fasthigh28645
Would be a great idea if the blackbird had a speedo cable - haha
The blackbird uses a speed pulse generator and is wired up to the speedo.
Check the connection on the back of the clocks - i managed to loosen mine when i was fighting with the dip beam bulb in the headlight.
Next check would be the earth on the clocks followed by the speed pulse wire itself
Another thought - Have you fitted a HID conversion ? - make sure the ballast box is over on the right hand side of the bike as you sit on it - they can sometimes interact with the bikes electronics.
