CBR 1100XX "Super Blackbird" 1998 - 2003 CBR 1000XX
CCT
Old Jan 8, 2008 | 10:56 PM
gjeatt's Avatar
Default CCT
Why hasn't any one thought of this Idea before for CCT rattles?
Iv'e heared all sorts of ways to stop rattling caused by this and that, but I don,t believe any of it. Cam chain tensioners rarely wear out or rattle on the end pin, if you look closely even a new one is loose on the end pin.
Sure a manual adjusting tensioner is a way to go, but try this first.
I heard that a VFR spring is stronger but hard to get cheap and on its own from Honda.
Heres what I did- whenyour tensiioner spring weakens just add 4 extra turns to the spring before assembly, I did this to an older one and gained 30% extra tension 1.200mg and I also gained 30% to a newer one that has just started to cause a rattle.
While I don't recommend this to a newCCt it should be OK for an older one, also if you dont know how to add 4 extra turns then I suggest you don't touch it at all.
I put the older one in and It's now quiet, more power (in my opinion), and I now have a spare, all without chasing a heavier spring or buying new one.
When (if) these wear our again i'll just go for a manual CCT.
Cheers ..save some of ya Money
[IMG]local://upfiles/23173/1C2C1DD909684F4A9643A70D3CA5E459.jpg[/IMG]
[IMG]local://upfiles/23173/C98A8C0FE72744D0A56704FCF5929FB4.jpg[/IMG]
Old Jun 16, 2008 | 10:30 PM
Flickthebird's Avatar
Default RE: CCT
I think you might have just voided your warrantee!
Old Oct 12, 2008 | 07:08 PM
fasthigh28645's Avatar
Default RE: CCT
Look for John Bike Bits in an internet search. He has the new upgraded CCT for the bird and its around $50.00. Can't go wrong there. It has an upgraded spring and it works. I put this on my 2000 bird and have had no more noise.
Old Oct 17, 2008 | 01:37 PM
Bob Z.'s Avatar
Default RE: CCT
John does not sell the upgraded CCT - he sells the OEM double green dot, which I recently bought and installed in my 10k miles Blackbird - cured the 3-4k rattle (aka bag-o-marbles sound). The upgraded CCT people talk about is for the X-11 and only available in Japan.
I would not put any extra tension on an old CCT since that is not good for the cam guides, etc. Besides, for about $35 you can get a new one from John. And since that is one of the few problems Blackbirds have it is money well spent.
