what is the best Sprocket size for wheelie?
Old Aug 15, 2009 | 01:31 AM
ikhatib's Avatar
Default what is the best Sprocket size for wheelie?
now dont calle ma a squid and duno what, i want to start doing wheelie on my 1000rr. my bike can do wheelie in the current stock sprocket but still i dont want to do wheelie on the first gear bcz i got a small sprocket in the rear and i dont like to do wheelie on the first gear bcz its not good for the gear box i prefer to go in my second gear and so on, so i need help with the best rear sprocket size.
10xs
Old Aug 15, 2009 | 09:35 PM
shaver's Avatar
Squid! Just kidding. The bigger the better broseph. Remember this though, when you change that sprocket...your speedo will no longer be accurate, you're going to loose top end speed like you wouldn't believe, and please....PLEASE....STOP doing 1st gear wheelies. That's the best way to loop your bike.
Old Aug 16, 2009 | 02:59 AM
ikhatib's Avatar
"your speedo will no longer be accurate, you're going to loose top end speed like you wouldn't believe"
we are talkin about -20km in every gear? well its a street bike and i dont think ill drive my bike faster than 170km and i know it can go upto 300 easily and that its first gear is 130km 2nd one is 180 so i think its ok with me but losing more than 50km as top speed i think its too much
regarding the sprocket size +2 in the rear is it enought or i should go for a bigger one?
and will i notice a big chage in the performace on my bike on low speeds? i mean ill b able to do wheelie on the second third gear easily or i wnt see a big diff?
10xs again
Old Aug 16, 2009 | 04:02 AM
WhiteKnite's Avatar
June 2009 ROTM
You could just learn to clutch it up.
I went -1 front and +2 rear and installed a speedo-healer. It felt great, HUGE difference, until I got a mess of electrical gremlins yesterday that is. I would highly suggest it unless you often cruise at over 130 kph, it drastically increased my RPMs at high speeds. I think it tops out at a bit over 265 now instead of almost 300.
Old Aug 16, 2009 | 04:09 PM
Chrisct713's Avatar
i went only +2 in the rear, it made a huge difference with wheelies and didn't affect my top speed very much at all. I got a speedohealer and at 80 mph (i dont know what that is in kph) im at 6,000 RPMS which isnt bad at all. The +2 in the rear now allows me to power up wheelies through 4th gear. It helped a lot with off-the-line starts too. If you're only interested in wheelies, I would suggest just going down a tooth in the front. Its roughly equivalent to going up three in the rear but its cheaper.
Old Aug 17, 2009 | 02:31 AM
ikhatib's Avatar
sorry guys but what do u mean by speedo-healer?
so i guess ama change ma rear sprocket +2, and iam thinkin of installing an Akrapovic exhaust or yashimura back exhaust with k&N filter.
10xs guys for the tips u r the best
Old Aug 17, 2009 | 08:34 AM
WhiteKnite's Avatar
June 2009 ROTM
Speedo-healer info here: http://www.healtech-electronics.com/
Your bike reads the vehicle speed from a sensor in the transmission, when you change to larger rear and/or smaller front sprockets your speedometer will read lower than it should. The speedo-healer re-calibrates your speedo by basically tricking it.
Going up 2 teeth in the rear is a good start, but if that's still not enough go one smaller in the front too, like I did. I lost less than 25 KPH but gained a TON of acceleration and low speed ride-ability. Use http://cbrtech.dyndns.org:8080/cbrtech/gearing.php to calculate how much speed you will lose due to gearing (you will be putting all that power into acceleration though).
I wouldn't bother with the K&N filter, I haven't heard good things about them. If you are looking to gain alot of power from your exhaust save up and get a full system and power commander. You won't gain very much noticeable difference from just an end-can. If you just want it for sound and cosmetic reasons go for it.
Old Aug 17, 2009 | 06:52 PM
TBagr's Avatar
i do all my wheelies in second and third gear and i have stock sprockets
Old Aug 18, 2009 | 03:43 AM
ikhatib's Avatar
oh bro many thanks.
u gave me tha info i needed i really appreaciate it.
ill do like what u said -1 front sprocket +2 in fron sprocket, ill check if i can find spee healer in oman i dnt thnk i can find one but ill try to get one.
regarding the full exhuast i cant afford it its too exp and i can barely afford the rear exhaust and cant find used exhausts here frankly where iam at their are few bikes bcz currently iam wrkin in the gulf and ppl here they like cars.
ok k&n filter ill gorget abt it.
many thanks again
Old Aug 18, 2009 | 03:54 AM
ikhatib's Avatar
ya u can do that but i think its not comfortable to ur bike esp when ur using stock sprockets, i dont know i believe that but its hard to do it with the stock ones.
03cbrsix
Oct 8, 2009 10:17 PM
bkglad
Jul 14, 2009 06:54 PM
Darin300
May 12, 2008 10:19 AM
waz57
Sep 5, 2006 12:30 AM
KillFranklyn
Jul 10, 2006 05:27 PM
