Sprocket size?
Old May 7, 2008 | 08:31 PM
Darin300's Avatar
Default Sprocket size?
Hey guys, what size sprocket in the rear are you running. Stock it shows 15/43 if I'm reading it right(final drive ratio?). My bike has a 15/48, seems to low, I do alot of highway riding. What you guys think? What about a 45?
Old May 7, 2008 | 09:01 PM
redzintimidator's Avatar
Default RE: Sprocket size?
Why not stick with stock? Works good on highways, rpms arent too high
Old May 7, 2008 | 09:59 PM
F3Rider's Avatar
Im running 45 in the rear.....at 70mph im at about 7k rpms
Old May 7, 2008 | 10:34 PM
killerc998's Avatar
i can tell u not to get a 54 tooth. i cant get above 70ish. cant really tell no speedo
Old May 8, 2008 | 06:35 AM
Mooseknuckle's Avatar
I'm running stock in the rear and -1 up front. When it comes time to swap out, I'm going stock in the front and +2 in the rear, which should be roughly the same (correct?).
Old May 8, 2008 | 10:18 AM
F3Rider's Avatar
ya its gonna be pretty damn close.....i think the ratio is for every 1 tooth down in the front its equal to +2.66 in the rear.....someone told me that at a bike shop
Old May 8, 2008 | 01:58 PM
Darin300's Avatar
Thanks alot, I think I'm going to try stock, but if 7k at 70 is ok then maybe also get a 45 to try that. This is my first bike, I have to try and stop thinking car. thesse like the RPMs huh? Thanks for the input.
Old May 10, 2008 | 03:44 PM
I just wanted to check and see what my speed was at 7k RPM. My speedometer indicates that I'm going 90 mph, but the actual speed according to my GPS is 84 MPH. I'm running the stock gearing of 15/43 and that's quite a bit different from 70 at 7K.
(editedfor grammer)
Old May 10, 2008 | 03:56 PM
ta8218's Avatar
Huh, in 6th I'm usually at about 70 at 7k. I'll check today for sure, but I'm 95% on that.
EDIT: with stock 15/43 gearing
Old May 12, 2008 | 10:19 AM
ominous1's Avatar
Mines runnin 13-43 ,PO. got to change that -1+2 i just dont like the 13 bad number That way its close to what im used too
bkglad
Jul 14, 2009 06:54 PM
rich fuller
Oct 15, 2007 09:08 PM
njaimet
Nov 12, 2006 12:38 AM
waz57
Sep 5, 2006 12:30 AM
KillFranklyn
Jul 10, 2006 05:27 PM
