Turns on My 1000rr Are Not Good
Old Jun 7, 2007 | 01:40 AM
jerado8's Avatar
Default Turns on My 1000rr Are Not Good
I just got a 2004 Cbr 1000 rr a while ago and i noticed that the steering is way diffrent than other bikes and it feels like it wants to fall into turns. What would be wrong with it, ive rode new cbr 600s and gsx 750 and 1000s and noticeds that none of those bikes have this problem could some one give me some advice on wat might be wrong or is that just the way this model is? Thanks
Old Jun 7, 2007 | 02:22 AM
dwhite645's Avatar
Default RE: Turns on My 1000rr Not Good
Your suspension probably needs adjustment
Air pressure
Squared tires
Just some ideas...
Old Jun 7, 2007 | 02:44 AM
Orangebutter's Avatar
Preload, compression dampening. Check them all out, they are proabably out of wack.
Old Jun 7, 2007 | 11:39 AM
RICHS65's Avatar
Check your tire pressure also.
Old Jun 7, 2007 | 04:18 PM
drop2's Avatar
Yes check your tire pressure first. May need new tires depending on mileage.
Old Jun 7, 2007 | 05:44 PM
gottabfordtough's Avatar
suspension may be too soft?
Old Jun 7, 2007 | 07:05 PM
071KRR's Avatar
Has the bike been previously wrecked?
Old Jun 7, 2007 | 07:06 PM
mininsx's Avatar
Default RE: Turns on My 1000rr Are Not Good
Check to make sure that it's got the proper size rear tire if it might have been replaced. A taller rear tire will quicken the steeringor lowering the front fork tubes slightly will have the same effect.
Old Jun 10, 2007 | 03:19 AM
jerado8's Avatar
thanks all of you for your advice, today i checked the pressure and it was a little low and i also went online and found the tuning settings for the front suspension and redid everything and i also lowered the ride height in the rear to give it more rake and it seams to be good now so thanks for all the good advice
Mrlutzcbr89
Sep 16, 2009 10:25 PM
Slavo04
Apr 11, 2009 10:54 AM
voodoochyl
Jul 27, 2007 08:15 AM
digitalbar
Jul 22, 2006 07:10 PM
jon_123
Jul 4, 2005 12:26 AM
