Stands
You are a good girlfriend! The best that money can buy would probably be Pit Bull. If you want to save some $$, check out T-Rex on e-bay.
T-Rex on e-bay
You do not need a triple tree for the front, but it would be nice to have.
T-Rex on e-bay
Yeah, the triple/steering head front stand is the best to get because you can do wheel changes AND remove the forks if needed.
+2 on PitBull stands. While you're getting him stands, make sure he has the swingarm spools for use with the rear stand. It's an 8mm thread on those and they're like $10-15 a set.
i have the pitbull that will either lift by the triples or the forks
for quick lifting the fork lift is easier but for reinstall of the front wheel or the forks at all lifting by the triples is the best way to go
yeah i know you can do the front wheel by the fork lift instead of a triple lift but it puts pressure on the forks and you dont get as many spins on the wheel after install
here is an excert off of rc51.org on how to do it
1) Get the bike up in the air on a front & rear stand. Front stand must lift from under the bottom clamp since the fork legs must be relaxed. The fork legs are the key to this whole thing ya see.
(2)Loosen up all the pinch bolts
(3)tighten the **** out of the fromt axle to make sure that the bearings are seated in hub all the way. Then immedaitely loosen up re torque to spec (?).
(4) Take your first spin baby. Got 6? No, OK, just seeing if you got lucky. If not read on, if so go to step 7.
(5)Drop bike to ground & compress the forks 10 or so times to get everything all good and settled & put er back up on stands. Got 6?, go to step 7.
(6)Now the fun part, DO NOT BE IN A HURRY, WERE WORKIN IN HALF MILLIMETERS HERE. Your fine tuning the distance between the bottom of the fork legs by putting pressure on the legs and tightening only the inner left(from on bike perspective)pinch bolt just enough to maintain the pressure on the legs. I can not emphasize how small an amount of bolt tightening and fork pressure I am talking about here. Start with small changes and check the spin. Try pressure pushing out and then in, just a little & then go to more pressure if necessary. Work your way around and spin regularly. Sort of like tire balancing, you know when your getting close. LDH's Ohlins' needed to be spread apart, my stockers needed to be pushed together. Either way this will work. There is a sweet spot in there somewhere that will yeild 5-6 spins.
(7) Got em?, good.. Now the most delicate part. Tighten the pinch bolts a half turn or so each with a spin every time you cycle through the bolts to be sure you have not shifted out of your sweet spot. If you shift out of the sweet try tightening in a different order or one side at a time untill you reach spec torque (?). DO not start all over, just loosen up to the point that you get your 6 spins back and try some other tightening pattern, maybe only do 1/8 turn. Its an art, not a science ya see.
(8) Phew, get a beer, relax. You just did the rc equivelant of sighting the abonimable snowman. He's out there & I saw him in my garage tonight.
Pitbull may be the most popular but it's not the best, cyclecat stands are so easy a 10 year old can do it, not to mention the quality, this is head and shoulders above every other stand i've used (yea i used to like pitbulls) however they are expensive. http://cyclecat.com/UCS01-01.htm
ORIGINAL: hondaboy44709
there is a company called Handy and you can get both front and rear for $100. I bought them over 5 years ago and still in perfect condition. I would recomend them.
