SERIOUS PROBLEM (MECHANICAL)
Old Jul 11, 2007 | 09:57 PM
blizzneck's Avatar
Default SERIOUS PROBLEM (MECHANICAL)
My close friend just had his bike modified (REPSOL- complete flapper valve removed, 520 conversion, custom map). Two (2) times on the Dyno the bike had a serious dip in power around 8500 RPMS and one time even stalled. The few runs after were flawless. On his way home from the shop (on I-95) his bike cut off (engine stopped) in sixth (6th) gear at 9000 RPMS. He said he red lined it in other gears butwhen the bike hit 9000 RPMS in 6ththe engine shut off???? WTF
of coarse the DYNO/BIKE shop was closed at this time, but he was able to make contact with the mechanic who stated he might have conected fuel lines wrong(while doing the flapper mod- prior to the dyno), is that possible? would the bike even run?? . Any one have anything for this. My friend would greatly approciate your response and I'm curious george.Friend is LIVID, sick to his stomach , understandable.
Old Jul 11, 2007 | 10:20 PM
ASAP's Avatar
Default RE: SERIOUS PROBLEM (MECHANICAL)
what does the flapper-mod have to do with the problem
[hr]
Old Jul 11, 2007 | 10:26 PM
CBattR1000's Avatar
you should check on the modification section of the cbr1000rr... i think i saw a post titled "flap mod dangerous"
Old Jul 11, 2007 | 10:55 PM
blizzneck's Avatar
ORIGINAL: ASAP
[hr]
to do the complete flap removal, gas lines and possibly electrical coonections were un-plugged and possibly reconnected wrong. Just listed the mods he had done today on his bikeas his bike was flawless prior to these mods. trouble shooting possibilities
Old Jul 12, 2007 | 02:56 PM
blizzneck's Avatar
PROBLEM SOLVED !
One of the four (4) injector connectors was not fully snapped in, causing the bike to run off of three (3) injectors. Once all connections secured, the bike ran flawless. I think he still is sick to his stomach, but obviously relieved. Thanks ya'll
mjp94cbr100f
Jan 1, 2013 12:42 PM
CBRnewbie
Feb 14, 2011 12:59 AM
Jay1623
Jun 15, 2009 05:08 PM
shaner
Jul 4, 2007 07:17 PM
RealCBRider
Dec 31, 2005 02:38 AM
