running with both headlights on
Old Aug 25, 2005 | 07:08 PM
shinysideup's Avatar
Default running with both headlights on
i was talking with some friends that said it might be possible to set up the headlights so they both run on dim and both on hi. havent actually seen it yet or heard of someone doing it. i looked at them briefly and am not sure how it could happen. im not to electrically inclined but can figure it out with instructions. anyone know how to do it?
Old Aug 25, 2005 | 07:46 PM
Anubis's Avatar
Default RE: running with both headlights on
Yeah its easy to do, look at the back of your lights towards the top outer corner on each there is a cross head plastic adjuster simply turn it anti clockwise to lower the beams height and clockwise to raise it. I focused mine on the garage wall to determine whether it was adjusted low enough not to blind a the cagers.
I only adjusted the full beam and left the normal headlight alone, thanks to MGA_Oden for puttin the original idea across.
Old Aug 26, 2005 | 11:46 AM
Dragon's Avatar
Thats not a bad idea...But i still would like to have both as lows and both as highs....I haven't heard of anyone doing that yet...With little work...
Old Aug 26, 2005 | 03:08 PM
Tahoe SC's Avatar
sigh...noobs...
BAM...
http://forums.cbrworld.net/forums/42405/ShowPost.aspx
tailor it to fit the RR...could be done following the link.
Old Aug 28, 2005 | 04:02 PM
i meant running with both lights on durring high and low beams. im going to tinker with it and see if i can find anything out. if so, ill get the word out.
Old Sep 7, 2005 | 07:22 PM
Repsol JF's Avatar
http://www.customled.com/PRODUCTS/MA...ic_blinker.htm
http://www.tobefast.com/detail.aspx?ID=876
Not sure if these will help.
Old Sep 26, 2005 | 02:01 PM
so, i rigged them both up to run on highs and lows, then heard that i might fry some wires and expensive stuff. so i took it all back off and am just running regular. i dont think its worth the hastle for me. i just want to ride!
Old Jan 13, 2006 | 07:14 PM
streetfighter's Avatar
the link above is excellent i did it but to both dip and main and light is great you just have to use two relays and a new power cable or you will damage your wiring and then make the bulbs fit which only take a few minutes the total conversion took my lunch hour to do and looks great [sm=exactly.gif] only do this though if you are good at electrics it is not hard but but if you are unsure get help or it could end in tears
Old Mar 22, 2007 | 12:36 AM
simoeseomis's Avatar
hey street fighter what kind or bulbs and realays dod u use and how didi u install them i would like to do this with my bike. can i still use the high beam switch for both? or are both high beam and low beams on at the same time....
oneway_4me
Feb 23, 2012 05:55 PM
entity-unknown
Mar 20, 2009 11:55 AM
CBR_600_Rider83
Mar 25, 2008 12:45 AM
devo_3386
Apr 30, 2007 07:29 PM
Rajj
Feb 15, 2006 03:01 PM
