help!!!! no headlights
Old Feb 21, 2012 | 01:13 PM
oneway_4me's Avatar
Default help!!!! no headlights
just bought 05 cbr. went to shop for new shoes. went for a ride and have no headlamps. bulbs good, no power to hi/lo switch, fuse is good. any thoughts. need wiring diagram also would help.
thanx
Old Feb 21, 2012 | 05:35 PM
estate4life's Avatar
February 2012 ROTM
1. Did you physically check the connection socket?
2. Check wire using tester for electrical current, work your way from the head light to the fuse or vice versa... If the bulb & fuse is good, 90% is the connection...
Old Feb 21, 2012 | 05:52 PM
oneway_4me's Avatar
I have ground at both plugs and no 12v. Checked all my connections. All ok. Is there a relay for lights?.
Old Feb 21, 2012 | 06:57 PM
February 2012 ROTM
So fuse is good, connection is good, no 12V?
Do your parking light, high beam & blinkers work?
Do bike have an alarm
System?
Regarding relay? I'm not sure but don't sound logically to have a relay to the headlight? But other members with your bike may want to jump in on this...
Did you check if there power to the fuse?
Old Feb 21, 2012 | 08:20 PM
99specz32's Avatar
is your lighting all stock?
I've seen and done in the past on my f3 when I did the f4i headlight swap I used higher wattage bulbs both hooked up to the lowbeam side and it ended up melting the solder contact point for a wire inside the right handle bar switch.
I've also seen this on another model honda I cant remember off the top of my head which one. but basically I had no lights high or low, fuses all good, checked for power and worked my way back using the wiring diagram, found power going into the right side control where it should but none coming back out to the harness. Pulled it apart and saw the wire hanging there where it's solder point had heated up and melted off.
not saying that's your issue for sure but regardless get yourself a multimeter or even a testlight and just work your way back using a diagram, find it and fix it
Old Feb 22, 2012 | 10:58 AM
oneway_4me's Avatar
okay. update. found relay at the tip of the nose behind cluster. have power at relay and all others is grounded. swap out relays still no lights. i have put on led turn signals . three wire system but only used two..... so they will blink but no park. taped up other wire and checked for short.... no short. when i force 12v to the relay the lights will work but my blue highbeam indicator is always on.. i need a diagram. checked all connectors. i am afraid i will have to split harness open and operate.... any more help would be appreciated
Old Feb 23, 2012 | 11:51 AM
oneway_4me's Avatar
okay fixed em... thank you to all who replied... problem in the starter switch, found broken wire.
Old Feb 23, 2012 | 05:55 PM
February 2012 ROTM
Great job!!! 90% connection....
danroonie
Dec 8, 2011 02:42 PM
OneWheel929
Jul 5, 2011 05:25 PM
cptspiller
Jun 2, 2007 03:44 PM
1000rrrider
May 6, 2007 07:58 PM
steve00ses
Aug 10, 2006 08:06 PM
