Melted Fairings
Old Mar 11, 2007 | 05:38 PM
jsukey's Avatar
Default Melted Fairings
Hey there, I'm trying to find out if anyone else is having any problems with their lower fairings melting on their 1000RR. I've got an '06 with 9100 miles on it. The right side fairing has a little brown spot on the Honda sticker. The left side fairing is already warped and the sticker is just about gone. Its never been down so nothing has been bent or anything like that. I have the stock header with Yosh RS-5 Slip-on. I went to the dealer and I will find out Tuesday if they are going to warranty it. Any info will be greatly appreciated. Thanks
Old Mar 11, 2007 | 08:26 PM
Zach_x's Avatar
Default RE: Melted Fairings
Yeah mine did it to, I just took the fairings off and wraped the pipe with that thermal tape, put the plastics back on and bingo no more problems
Old Mar 11, 2007 | 08:31 PM
the greeen lantern's Avatar
use header wrap,it looks awsome and it works
Old Mar 11, 2007 | 10:25 PM
kodiak1122's Avatar
Anyway to post up some pics?
Problems and the fix.
Old Mar 11, 2007 | 10:29 PM
openclasspro's Avatar
ORIGINAL: the greeen lantern
just don't get it wet- retains moisture rusts out pipes- been there seen that
Old Mar 11, 2007 | 11:48 PM
Zach_x's Avatar
Oh yeah I should have mentioned that, I didn't think about it cause my bike never leaves the garage when its wet out.
Old Mar 13, 2007 | 12:10 AM
2rawcbr's Avatar
Wuzup, I had that problem, I have a 2Bros Vale slip-on, although the problem started before I switched out the pipe. I order "Heat Tape" from Two Brothers website. I put that on the inside of the fairings and the melting stopped. Just in case you haven't found another solution. Good Luck with that, ride safe, ride hard.
Old Mar 13, 2007 | 12:26 AM
Dublerdave's Avatar
I used header wrap also. Works great. I'll have some pics up soon
Old Mar 13, 2007 | 11:13 AM
vinnyzcbr's Avatar
instead of wraping the header, guard the inside of the fairing to reflect the heat. im not sure what but thats what i would research and do because you never know if your going to be caught in the rain.
Old Mar 20, 2007 | 02:48 PM
CBR_Rod's Avatar
Those who don't ride in the rain, do you not wash your bikes?
Dave600FS
Aug 16, 2013 04:39 AM
WildTay
May 14, 2012 12:21 PM
dwhite645
Jul 30, 2009 02:21 PM
thewurm
Sep 12, 2005 01:42 PM
WhiteTailCBR
Jun 10, 2005 11:15 AM
