Lowside... TIRES AT FAULT?
ORIGINAL: openclasspro
got bumped to expert class in ccs in 01 fwiw,it takes alot for an individual to outride an oem tire on the street-unless it was a road issue or say a tire that's never ridden to it's edge then all of a sudden take to it's full apex pt
From following this post it seems like your weight might be shifted slightly back, if your rear tire is scuffed to the shoulder than the front tire shouldnt have a chicken strip anywhere, Your suspension settings up front might be off or your not staying up on the tank. Ive rode several different tires and they all work well for aggresive street riding as long as your bike is setup correctly.
i have the same issue with the front still haveing chicken strips and the rear being scrubbed to the edge, I thought it was just from the fact that front tires are narrower and taller then rear tires. so if you bike was leaned enough for the front to be on the edge, you would be out of back tire.
