Hopefully gonna be getting an 1KRR
Old Jun 7, 2006 | 08:33 PM
brancart1's Avatar
Default Hopefully gonna be getting an 1KRR
I was wondering if there were any major things i should be looking for when shopping for a good 1000RR. I mean i have an F4i right now and have been riding for a long time, but our bikes all had problems with the CCT's, and was wondering if the RR's had similar problems. Thanks, and any advice is appreciated.
Old Jun 7, 2006 | 09:03 PM
1000RR's Avatar
Default RE: Hopefully gonna be getting an 1KRR
No major problems really.
If it's a 2004 (early) make sure the speedo was recalled/replaced.
If not, and if it IS defective, make sure you read up on this and know
whats going on. If it WAS replaced, make sure you get the REAL mileage
from the owner. Service records don't lie. Don't take the ODO reading as gospel.
Know that the 1000RR engine is very noisy. At first it sounds like all the
valves are clacking and ticking. This is normal. Most ppl belive it's the injectors
making the noise.
Alot of the 600RR's smoked. My 1000RR used to smoke a bit when it was newer,
but not even a hint now. A "little" smoke on a hard throttle blip on a newer bike
wouldn't freak me out. I wouldn't like it but don't panic.
Because of the floating rotors, the front brakes will drag a little and sound like something
is warped. It probably isn't.
Some people reported discoloring of the fairings on the RH side where the Radiator overflow
hose is. Also check for cracks around the back mounting holes of the mid fairing.
Other then that, just use your commen sense.
Old Jun 10, 2006 | 06:12 AM
brancart1's Avatar
thanks
02F4I1987
Feb 12, 2012 10:58 PM
N1inc
Jun 12, 2011 11:30 PM
maineiack
Jan 29, 2010 10:01 PM
rangerscott
Jun 13, 2008 10:08 PM
ChrisMac
Jul 18, 2007 12:46 AM
