help installing a laser extreme exhaust 2 pipes on 06 1000rr
Old Apr 1, 2009 | 06:39 AM
McCullough's Avatar
Default help installing a laser extreme exhaust 2 pipes on 06 1000rr
Whats up, All
I'm new to it, so much help is needed. Going to try and install the laser extreme exhaust w/ the two pipes on my 06 1000rr. Any knowlege or trick I need to know be for i I start, to make it as smooth as possible to install. Also, adding a hotboddies undertail hit w/ LED, and flushed mount light up front. Any and all help I thank you a thousand times.
ride safe!
ride smart!
Old May 2, 2009 | 05:07 PM
m007slater's Avatar
you need to buy some quality heat reflective tape and tape the underside of the exhaust system , as you will be removing the aluminium heatshield to install the pipes ............... and you will need some exhaust sealing putty to as you dont want to find a leak after bolting it all together .........i have this system so knowledge of it is first hand ............
Old May 6, 2009 | 09:14 PM
woodchopper's Avatar
Registered Users
dam it will sound pretty sweet man
Old May 12, 2009 | 07:43 PM
07ceeberthousand's Avatar
can you guys point me in the direction where i can buy a laser xtreme exhaust? i try google searching a 07cbr1000rr version of the laser xtreme but i get model years 04thru 05 and a 06 pipe... i realize the 06 is essentially the same as the 07... so will it work if i buy a laser xtreme exhaust intended for the 06?
McCullough
Mar 29, 2009 07:22 PM
Asmittie84
How-To: Mechanical
Feb 13, 2008 12:28 PM
dizzie56
Aug 8, 2006 07:53 PM
m007slater
Jul 30, 2006 05:46 PM
jmere67
Nov 23, 2005 11:23 PM
