Help! 2008 CBR1KRR won't start!
Old Aug 13, 2008 | 03:19 PM
srvfan99's Avatar
Default Help! 2008 CBR1KRR won't start!
Hoping you all can help. I have searched through the other simlilar threads and didn't see one for the '08.
My '08 CBR1KRR won't start. I rode it all day about a week ago. Tried to start it over the weekend and NOTHING. Starter turns over, fuel pump works, all the fuses associated to the ignition are good. Seems like I'm not getting a spark. I replaced the battery just to make sure (lifetime battery warranty).
Does anyone know where the ignition coil is located? Any connectors I need to check?
Thanks for your help.
Dave
Old Aug 13, 2008 | 10:21 PM
CBRCRF's Avatar
Default RE: Help! 2008 CBR1KRR won't start!
Kill switch?
Take it to the dealer if you cant figure it out. Its under warranty. You never know, it could be something bad.
Old Aug 14, 2008 | 06:15 AM
crossbreed's Avatar
if it is in gear and the kick staind is down it will not start or if the kill switch is off! if its not this dealer hear you come!
Old Aug 14, 2008 | 06:41 AM
srvfan99's Avatar
Well, it finally started this morning. I didn't do anything different than I did for the last couple days, but it started.
The original issue was the battery. After I replaced the battery, then only other explanation I have is that the engine was flooded from me trying too many times to start it.
This morning, when I was pulling out my CBR600F3 to go to work, I gave it another shot at starting the 1krr. Held the throttle wide open for the first attempt to clear out any excess fuel in the cylinders. Second attempt, normal start procedures, and it started right up. The exhaust was pretty heavy, so I can only guess that it was flooded from trying to many times after the battery swap. I let it run for about 5 minutes then shut it down. I'll start it up again this evening when I get home. I'll let you know how it goes.
Thanks to everyone for your concern and suggestions.
scivir16
Sep 14, 2011 04:49 PM
white_knuckled08
Jul 26, 2009 10:28 PM
creed32
Jun 29, 2008 08:56 AM
XXCBRChrisXX
May 3, 2007 01:56 PM
