gas light stays on
Old 06-20-2007 | 11:37 PM
GraveyLastGearMC's Avatar
Default gas light stays on
anyone have this issue...my gas light is stuck on....i have a full tank and its still on....can't figure it out lifted the tank and nothing looks disconnected...
Old 06-21-2007 | 02:36 AM
menefreghista's Avatar
Default RE: gas light stays on
can ya drain and top it off again to see if it goes away ?
Old 06-21-2007 | 04:17 AM
cbrmarshall's Avatar
I have the manual for the 2004 to 2006 cbr1000rr. Fuel reserve sensor - Fuel reserve indicator does not go off : Lift and support fuel tank. Disconnect the fuel pump unit 3P (black) connector. Turn the ignition switch ON and check the fuel reserve indicator. If the indicator goes off, replace the fuel pump unit. If the indicator is still on, check for short circuit in Brown/black wire between the fuel pump unit connector and the combination meter. I hope this helps. Sounds like the float is in the fuel pump unit. You might shake or bump the fuel pump unit, float might be stuck and hopefully if you unstick it, it won't stick again. Good luck!!
mtz
09-02-2012 02:48 AM
rictic525
06-18-2012 10:14 AM
lcpl1014
06-29-2011 10:18 AM
dumptransit
10-31-2008 11:28 AM
Kingpat
03-31-2006 07:28 PM
Quick Reply: gas light stays on
