front sprockets and gaskets
ORIGINAL: baxsom
what gasket, the paper one behind the sprocket cover
ok gotcha,
you have to take the slave off,
because the bolts that hold the slave on go into the sprocket cover.
the paper gasket behind it will be fine to reuse as long as it doenst fal apart when taking it apart.
if it does tear, just use hondabond or equivalent to seal it back.
the paper gasket behind the sprocket cover is completely useless because it doesnt seal anything. it is just there to go over the sprocket and to give the slave cylinder another mounting point
did the swap last night and the gaskets held up. the only minor hick up was the spacer stuck to the cover. this made it so the cover would not come out. i messed with it for 5 minutes before i realized what was going on. i was saying to myself there is no way you have to take the water pump off to change a frigg'n sprocket. once i figured it out it was a breeze. i was bummed i could not ride it to work today.
CBR327
Jul 28, 2013 05:26 PM
Atmbomb
F4i - Wanted
May 28, 2011 10:19 PM
