Front gear help
Old Oct 9, 2006 | 12:35 PM
dizzie56's Avatar
Default Front gear help
Im removing my swingarm and while im doing that im gonna replace my front gear n do a 520 conversion. only problem is that i cant get the gearshift cover off cause the water pump is in the way. was wonderin if there were n e tricks in gettin this thing off w/o having to drain my radiator fluid in the process.
Old Oct 9, 2006 | 12:55 PM
FATHEADS1KRR's Avatar
Default RE: Front gear help
There are three bolts that connect the pump to the engine. If you just take them out, and not the others, you can swing the pump out of the way enough to get the cover out from behind it w/out draining coolant.
Old Oct 9, 2006 | 01:11 PM
dizzie56's Avatar
cool. thnx. it looked like i could do that i just wanted to make sure instaed of openin it up n coolant fallin all over my ars
Old Oct 9, 2006 | 03:33 PM
You might want to put a lil lube on the o-ring when you put it back in too. Mine was pretty dry and i didn't want to tear it. You'll see what i'm talking about when you sep it from the engine.
Trent Dog
Jul 9, 2012 06:32 PM
patmetz
F2 Tech
Oct 15, 2010 10:31 AM
jstew600
Mar 8, 2008 02:41 PM
L8X
Mar 21, 2005 06:59 PM
