Front brake pad problem with EBC pads
In an earlier post, I talked about my brakes dragging and making noise since replacing the pads with EBC pads.Iordered another set of EBC pads, but the problem continued.I then replaced the EBC pads with new OEM pads and the problem went away.
how long did you use the ebc pads for before you took them out again ? the reason i say this is because i had similar problem , it was due to the fact that the ebc pads are slightly thicker , causing them to rub a little at first usage and when you push the bike with engine off you could hear a slight rub now and then ......................if yours at making a noise that you can hear whislt riding then their is something else wrong ........
