Fork Adjustment
Old Mar 11, 2006 | 01:21 AM
chainstretcher_ryan's Avatar
Default Fork Adjustment
I need some help. With everyones knowledge and wisdom could someone point me in the right direction. I have been doing my own maintenance and what not but last time I put my new tires on I noticed the forks where kinda cocked from the position of the wheel. I know all I did was put my bike on the stands and remove the wheel. About a week ago I let go of my bars and got alot of chatter at about 35. I put it back on the stands and compare the center line of my wheel and the postion of the bars and it seems that my wheel is pointing about 2 or 3 degrees off center. Anyone know how I can fix it. I thought about taking the wheel off lining my bars up and using a level to bring the bottom of my forks back. But not sure. Any info would be great.
Thanks Ryan
Old Mar 11, 2006 | 07:41 AM
chainstretcher's Avatar
Admin Emeritus & MVN
Default RE: Fork Adjustment
Have you hit any major bumps? Sounds like you've got a slightly bent lower leg(s). Remove the wheel and rotate each fork leg 360 and check alignment (there's a bolt hole at the very bottom of the fork and rotation will be around that axis). If the lower leg(s) are bent it's not a difficult job to replace them but they are expensive[:'(]
Only other thing that comes to mind is if your upper tubes are cocked in the triple tree.
Old Mar 11, 2006 | 07:56 AM
Anubis's Avatar
What Bike is it you have? Could it be the clip ons slighty mis-aligned? ?
Old Mar 11, 2006 | 07:36 PM
No, no hard bumps are anything. I avoid them ont he road. I rode all last year and had no problems. Will the lower legs just rotate or do I have to use something. I know how touchy suspension is, I don't want to mess anything up. I have the 1000RR '05. The thing is if I am at higher speeds she will hold a line fine, but I don't want to be cuttin the hills and find out somethings not lined up. Is there a good way to get the symmetry back for the front. Like using a level or some string or something to check it. Thanks again guys.
driyac
Jul 11, 2010 02:40 AM
civicblade
Apr 23, 2009 08:24 AM
WhiteHawk
Mar 17, 2009 10:17 AM
frankmackie
Aug 7, 2007 01:06 PM
ntirorider
Jun 14, 2007 04:44 AM
