Flapper Mod Removal?
Old Aug 15, 2006 | 12:56 PM
dizzie56's Avatar
Default Flapper Mod Removal?
I went to rogue racing and saw the flapper mod but didnt c how he removed the pieces entirely. Anybody know how? Chain i know u gotta know where a link is somewhere.
Old Aug 16, 2006 | 12:40 AM
baxsom's Avatar
Default RE: Flapper Mod Removal?
there is a thread on 1000rr.net about it but not really a write up
basically tank rotates up
airbox off
there are two pins on the grate in the front of the bike
pull those take the grate out
slide the intake forward and take the two phillips head screws out holding the two halves together
voila the flap comes off
the gold diaphram rotates out but then you have to plug the hole
i just clipped off the hook and put the diaphram back in
the vacuum canister, solenoid and wires are under the left mid fairing
one vacuum hose goes to the left side of the throttle body and has to be blocked off with a nipple
not the best description but I figured it out and i am an idiot so anyone can do it
Old Aug 18, 2006 | 05:01 PM
dizzie56's Avatar
sounds way to damn involved to do when not needed. thnx tho for the input
Old Aug 18, 2006 | 06:06 PM
chainstretcher's Avatar
Admin Emeritus & MVN
He made it sound easy too -- when actually removing it you'll have parts and pieces scattered to the winds[8D] I can't say removing it actually made that much difference over just plugging the hose but I guess it could have. If you ever decide to go with a full exhaust I'd suggest removing the flapper otherwise I'd skip it -- to remove those phillips head screws he mentioned you gotta be some kind of contortionist.
Old Aug 18, 2006 | 08:29 PM
baxsom's Avatar
the only reason I did it is because i had to remove the air box to get into the pair valves anyway
IMO i wouldnt have done this if i was not already in there
just pull the hose
off of the diaphram until you want to get to the pairs (backfiring on decel from an exhaust mod)
Old Aug 19, 2006 | 06:38 PM
Boosted521's Avatar
no power is made over removing the system vs. unplugging the hose. the only added advantage is weight, and you only lose 1-2 lbs. so it's definately not worth the work.
Old Aug 20, 2006 | 10:19 AM
baxsom's Avatar
agreed.
Old Aug 30, 2006 | 01:26 PM
1000RR's Avatar
Save up some cash and get an A-Tech intake. Saves alot more weight and adds a few ponies.
rellimdekim
Jun 17, 2009 08:54 PM
eekenterprises
Jan 19, 2009 09:05 PM
medicbaldwin
Mar 30, 2007 01:11 PM
cbrrookie
Aug 21, 2006 08:42 PM
Chinchilla
Jul 26, 2005 12:50 AM
