Flapper mod Help
Old Aug 19, 2006 | 03:29 PM
cbrrookie's Avatar
Default Flapper mod Help
sorry fellas for bringing this subject up AGAIN....
I came across the threads about flapper mods.
As far as i knew a flapper modd was just unpluggin the hose and plug it with something like a srew Right?
but as I read everybody keeps talking about hidden screws (this is only to remove the assembly completly right???) the more I read the more I get confused.
A little help needed...
It seems people (no offense to anybody) make it harder that it seems or maybe i'm just not understanding it right.
thanks in advance...
Old Aug 19, 2006 | 04:28 PM
dizzie56's Avatar
Default RE: Flapper mod Help
The removing of the hidden screws is only needed when u wanna remove the whole thing. Check the site out
www.rogueracing.org
Old Aug 19, 2006 | 05:31 PM
baxsom's Avatar
yeah all you really have to do is pull the hose off of the gold diaphram like in the picture and plug the hose
i went so far as to remove the hose from the vacuum canister that it was attached to and plug the canister but eventully since i had to take the airbox off to get to the pairs anyway, removed the entire flapper system
remember though if you take the gold diaphram off you have to plug the hole it left behind
i just left the diaphram in place to plug the hole
Old Aug 19, 2006 | 06:31 PM
Boosted521's Avatar
^ i also just removed the hose and capped off the plug. cleans things up a bit.
Old Aug 19, 2006 | 08:06 PM
cbrrookie's Avatar
thanks for the info fellas.
So If I just plug the hose I can just leave the canister alone.
Sweet...
will be doing the flapper mod tomorow and by next week I should be able to get a PCIII
and than map it.
Old Aug 20, 2006 | 05:33 AM
Boosted521's Avatar
yeah, the bronze canister/diaphragm you leave alone.
Old Aug 21, 2006 | 08:42 PM
GEARHEAD69's Avatar
Yep easy mod to do less than 10 minutes, and OH what a sound!!! YEAHYA!!!
burritoeatinmex
Mar 15, 2011 06:39 AM
ss954rr
Mar 14, 2007 01:46 AM
mtm
Dec 22, 2006 05:27 PM
DIZZLE
Oct 24, 2006 08:35 PM
briand7878
Sep 26, 2006 10:40 AM
