Engine refuses to start after accident!
Old Dec 28, 2006 | 07:34 PM
crazy1000rr's Avatar
Default Engine refuses to start after accident!
Hi guys i'm new to this forum.
Had an accident with my bike, the water pump with the inner base too was damaged and needs to be replaced.
I've ordered for the parts but meanwhile i tried to start the bike to see if there is more damage in the engine.
There is no oil in the engine and the light is on, the engine is turning but not starting.
Each time i try to start it, the lights on the speedo and the headlight go off as if the batt is low.
The engine turn 2-3 times till it stops exactly as if the batt is low.
The HISS light is off since this accident, How can it affect the engine start and how to turn it on again?
Can you people help me out on this as i don't know much about cbr1000rr.
What can stop the engine from starting?
After the accident i replaced the damper with the oem HESD system.
Some people here say that it should be reprogrammed etc but i don't really like to send my bike here and there for repairs so i'd also like to know where there is any programming kit that includes the software and wires(to connectthe cbr 1000 to a laptop) for sale.
Any suggestion wud be nice from you people because i'm fed up with this motorcycle now.
Cheers..
Old Dec 29, 2006 | 04:39 AM
dwhite645's Avatar
Default RE: Engine refuses to start after accident!
I'm guessing it's probably your tip sensor, or bank angle sensor. I'm not sure how to reset that, but my guess is you have to unhook the neg battery cable?
Old Dec 29, 2006 | 09:18 AM
blade17fire's Avatar
I see that you mentioned the engine oil is drained dry..then why on earth in the 1st place you try to start it up??
It'll cos more problems for you..
Old Dec 29, 2006 | 01:56 PM
Hey guys thanx for replies.
Trying to start it to c whether it's worth buying the parts or scrap the bike.
The parking stand sensor was hanging and i've put it back in place.
I know it is damaged but i wonder whether it will affect the engine start as it is in neutral so whether the stand was down or... it should start??
Am i right?
Do you guys know whether the fact that there is no oil in the engine prevents it from starting cuz the oil light is on!!??
Thanks again
Old Dec 29, 2006 | 06:51 PM
Blue Fox's Avatar
Retired Moderator
Dry starting is way up there on the list of what NOT to do to an engine. I cringed when you said you did that.
There could be a thousand different things that could be the cause of the engine not starting. If I were you, I would take it to a shop.
Old Dec 29, 2006 | 09:43 PM
04dublr's Avatar
I agree that you should not even think about starting it with no oil it in. You dont have to put the top of the line oil in it for now, just put some in it. Your only gonna be out a few bucks instead of a few hundred or more for a motor. Your about to destroy it that way and it may not allow it to run w/ no oil in it.
Old Dec 30, 2006 | 11:08 AM
dizzie56's Avatar
I had the same problem after my accident, then i realized that it was somethin small like me havin it in gear wit the kickstand down. Regardless, u should spend the $40 more or less and put some oil in the bike b4 u go and try startin it. Who knows, there may not be that big of a problem now but if u run it wit out that oil its gonna b a whole lot bigger. Let me know if ur gonna scrap the bike cause i might wana buy some parts if ur sellin them
Old Jan 1, 2007 | 03:22 AM
hobbs51's Avatar
do you call yourself crazy1000rr because you are. anyone with a thought process at all would no not to crank that dam engine with out oil. WHAT IS WRONG WITH YOU.just one turn with out oil can damageall of the bearings in the motor are youthe far gone or did the crash effect you that way.
Old Jan 2, 2007 | 06:59 PM
hobbs51 I wasn't born mechanic so how the hell do U THINK I WUD KNOW?
If i knew then i wudn't have asked help from the forum!!
If u can't help plz do not reply...
For the rest of u guys thanx for the help..
Cannot put oil in the system as the water pump base is damaged and oil is leaking.
Will send the bike to a mechanic, I'm pretty sure it's the tipsensor doin it.
Anyone knows anything about component coding or programming??
Plz give me some links so that i can learn abt it.
Heard this bike works like a BMW with all the electronic etc... and that it need coding, programming..
Where can i get the software and cable etc..?
Thanx to all those who help...
Old Jan 3, 2007 | 09:59 PM
hobbs51's Avatar
ok crazy 1000rr,
maybe i went a little over board and will ask for your forgiviness iam not to big to do this. but every one else that posted in a way stated that starting the engine without oil would not be wise. iam sorry you had your accident and hope you get every thing worked out i no what i would feel like if mine were not running. seems like given you a little time you will get everything worked out.
Mike_Tuinstra
F2 Tech
Oct 12, 2010 09:21 AM
Arronaxx
Aug 12, 2008 07:38 PM
bquick
Jul 15, 2007 03:48 AM
bluRSXtypeS
Feb 24, 2006 08:04 PM
bluRSXtypeS
Feb 18, 2006 06:18 PM
