Charging problem
Old Dec 9, 2009 | 08:12 PM
mjimenez1's Avatar
Registered Users
Angry Charging problem
I have a 2005 1000rr. I have replaced the stator, rectifier and i have a new battery. After riding for a while, i turn off the bike and it wont start, the battery loses voltage and cant crank the engine,please help!!!!!!
Old Dec 10, 2009 | 05:24 PM
titaniumcbr00's Avatar
Did you replace all the parts at once, because you might have burnt the regulater/rectifier or the stator again.
Old Dec 27, 2009 | 12:04 PM
NVliterbike's Avatar
there was a TSB/recall/warranty extension of some sort...
http://www.1000rr.net/forums/showthr...=stator+recall
(Sorry for the link but it has good info)
Old Feb 5, 2010 | 07:20 PM
tcspits06's Avatar
i have a 08 with the same problem how do you know wich to replace?
Old Feb 6, 2010 | 08:00 AM
TBagr's Avatar
yes...take it to the dealer.
Old Feb 6, 2010 | 09:28 AM
Project96's Avatar
If the 08 is still under warranty then I would take it to the dealer. It prolly wont cost you anything. Dont have some joe shmoe try & fix it if its is under warranty. They might mess something up & cause it not to be a warrantable repair.
For the 05 you need to check the stator output & check to see if it has grounded. What kind of volts are you getting at the battery? As asked before was everything replacedat once? You could have replaced something & it not fixed it & the battery is now bad. Did you make sure to install dowel pinsin the case & that one didnt get stuck on the flywheel? I have seen it before is why I'm asking.
What volts are you getting at the battery?
Check stator output. (AC volts)
gdjohny
Jan 10, 2014 12:09 PM
blaster
Nov 19, 2007 12:02 PM
jasonp
May 2, 2007 02:44 PM
octec
Aug 24, 2005 05:03 PM
