Chain freeplay
Old May 15, 2005 | 06:49 AM
vtalin's Avatar
Default Chain freeplay
Does anyone think the 1-1/4" freeplay in the chain seems excessive? My 600F3 only had 9/16" although the swingarm is quite a bit shorter. Seems funny to see the chain ride across the guard on top on the swingarm.
John
Old May 15, 2005 | 05:23 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Default RE: Chain freeplay
1 1/4" is the max I'd let it go. I try to keep mine at 1". We have some severe bumps around here and I've yet to max out the chain.
Old May 16, 2005 | 04:26 PM
vtalin's Avatar
Chainstretcher,
When you measure the 1", is that from the point where the chain naturally sags to the same point of the chain after you push it upward with minimum pressure?
Old May 16, 2005 | 06:21 PM
MgA_ODEN's Avatar
Old May 16, 2005 | 06:46 PM
ORIGINAL: vtalin
Chainstretcher,
That's pretty close to how I check it -- only difference is I push it down slightly and then push it up. And as you see from the pic 1" is O.K. If your chain actually made it to 1 1/2" you'd notice a helluva racket upon rapid deceleration using engine braking.
Be careful following the manual to the "t" -- it also says to torque your rotor bolts to 14 ft/lbs. I farkin dare you to do it ... c'mon, it's a dare ... a triple dog dare ... ya, that's what I thought ... puss[8D]
slapshot1540
Mar 31, 2012 02:28 AM
backyardmechanic
Jun 26, 2011 04:29 PM
simo1000rr
May 10, 2007 08:49 PM
Cypress_CBR
May 4, 2007 12:54 PM
BlindLOKI
Mar 9, 2007 05:41 AM
