Alternator Questions
Old Jun 14, 2008 | 09:36 AM
gursh d's Avatar
Default Alternator Questions
I need to access my alternator. I took off the 8 or 10 bolts from the alternator cover, but am not sure wether I should drain the oil or not.
I noticed when removing the bolts from the alternator cover that there was some oil on my hands. Do you need to drain the bike's oil before you take off the alternator cover?
I know the alternator's bearings need lubrication, but engine oil shouldn't be flowing on that side, right?
Old Jun 14, 2008 | 10:44 AM
jwp6114's Avatar
Default RE: Alternator Questions
Correct, (for an 04, not 100% sure about the 08)i have personaly changed my stator and when i took my cover off that side was dry. the bearings that are on that side of the crank have a seal on the outside. therefore the bearing gets lubed but lets no oil into the stator side.
Old Jun 14, 2008 | 10:52 AM
gursh d's Avatar
oh sorry, I should have mentioned it's on '07.
Thanks for the help.
Old Jun 14, 2008 | 05:06 PM
jwp6114's Avatar
should be the same.
hmm
Aug 28, 2013 07:21 AM
daniellebryce
CBR1000F Wanted / Swap
Sep 20, 2012 03:37 PM
Thanatos
Aug 24, 2010 03:20 PM
onugreen
Oct 2, 2007 09:25 PM
