adjusting suspension for another rider
Old Mar 4, 2007 | 06:20 PM
gottabfordtough's Avatar
Default adjusting suspension for another rider
do you guys adjust your suspension for an additional rider each time or when your by yourself do you just leave the firm setting?
Old Mar 4, 2007 | 10:58 PM
taylorac's Avatar
Default RE: adjusting suspension for another rider
may be i not understanding but are you talking about adjusting the suspension every time some one other than you rides your bike. If thats the case why is someone other than you riding your bike so often. I got boys too but they are not always on my bike. Im just trying to understand your post.
Old Mar 4, 2007 | 11:31 PM
cjp48's Avatar
I don't carry passengers on the back. But if I did, I would adjust the rear spring pre-load.
It really depends on how the bike feels, and how far you are going to ride. If its a longer
ride, then you may want to consider setting it for the additional weight.
If you leave the bike with the standard settings, it will most likely wallow around and feel
a bit sluggish - especially when making turns and it may bottom out on larger bumps.
Hopefully, others that ride 2-up regularly can give you some more detailed information.
Good luck
Old Mar 5, 2007 | 12:05 AM
yes i was talking about riding with a passenger. i am probably a little on the light side with only weighing 150. i barely squat the bike when it's just me. but i just thought with my wife on alsoi should probably set the rear preload a little more on the stiff side . i figure i can adjust the dampeningto a medium-stiff setting and just leave that alone. but i thought a quick turn of the rear spring pre-load might be a good idea each time. i drive it to work and back but we try to get out on it alot on the weekends and stuff so i figure for that i could adjustit.
Old Mar 5, 2007 | 12:46 AM
vinnyzcbr's Avatar
i make the rear dampner all the way hard when my wife and i ride, i find that it lessens the weight transfer when accelerating, which my wife likes because she dosent feel as much like shes going to fall off the back.
Old Mar 6, 2007 | 08:47 PM
CBRU crazy?'s Avatar
Did your bike come with the tools to adjust the rear spring?
Old Mar 6, 2007 | 10:41 PM
ofcourse not. i gotta get a spanner tool. i seen them at the local shops for about 25-30 bucks. i was hoping to find a happy medium for the dampener and front and just adjust the rear spring for the weekends (when the wife will ride with me mostly).
Old Mar 7, 2007 | 01:27 AM
jchavers_2000's Avatar
Does anyone elses front seem squishy? Do i just use a flat head and turn 1/4 turn to right to make harder? How do I adjust rear If I make to hard cn it cause problems in turns? I have told kit from 06gsxr 600 will they work on honda springs? My dealer left out the user manual so I got to go get it.
Old Mar 7, 2007 | 07:57 PM
owners manual is great. tells how to adjust each setting and how it came factory...
yes i feel like my front dives when i tap the brakes.
shelzbot629
Apr 10, 2008 02:17 AM
areacode312
Jun 26, 2007 04:18 PM
95HondaCBRF3
Apr 11, 2007 12:24 AM
wheeler6747
Aug 18, 2006 07:00 AM
92CBR600_22
Apr 26, 2006 07:38 AM
