Who knows Hoses?
I know when i lift my tank as you have done there are no hoses connected in the middle of the tank as the photo would suggest.
I have just started a service so will take note tomorrow when i lift the tank to do the plugs.
Aussie Johnno
Aussie Johnno
Hey:
Your missing the fiberglass heat mat that goes under the tank #13 in fiche. Handy in the hot WX we have been having lately. You can make one from Hot water tank wrap/auto sun screen mat (dollar store) the two flex tabs in pic hold it on ( oops just notice one is broken off double sided tape will work on the right side), just cut to fit under the tank, just cut out for hoses and such, it reflects the engine heat away, it helps with fuel evaporation so you may get more miles from your tank. You can run a hose from the small nipple to thru the swingarm area to remote that vent, just make sure its kink free. The other larger one is the fuel overflow vent as stated above, no hose on it.
http://www.mrcycles.com/fiche_sectio...1996&fveh=3025
Dub
Dub
