Valve Stem
Old Mar 21, 2008 | 10:40 PM
Default RE: Valve Stem
Did you have to remove the tire ?
Old Aug 21, 2008 | 08:12 PM
usetheffours's Avatar
old post i know. but the 2x4 under a car does the trick. i had the a valve stem rip shortly after a small time shop replaced my tire. bought a stem, used the 2x4 to break the bead just as in idodirt's link. was able to push tire down by hand and install new stem without breaking the bead on the oppisite side of the rim.
Old Aug 21, 2008 | 10:37 PM
Shadow's Avatar
Hope you used a Porsche or a Ferrari for a counter weight or it won't work.....
Old Aug 22, 2008 | 08:10 AM
TimBucTwo's Avatar
ORIGINAL: samron333
Anyone ever replaced their own valve stem? Mine broke and I can't keep air pressure. I really don't feel like paying a shop the same money it would cost to install a tire. Anyone have any advice so I don't have to spend $80?
It is a simple task. You need a doner tire for the new plunger and the tool. I have replaced many on bicycles,cars and motorcycles. You un-screw the old one and install the new one.
This will help seal if the plunger is leaking. If the steam is leaking at the wheel you will need to have the tire removed. Place some spit over the the stem and watch for bubbles.
http://www.pitposse.com/tivareto.html
Edit: Any bicycle shop will have the tool and new plunger.
Old Aug 23, 2008 | 05:32 AM
weekendrider's Avatar
mark the tyre then do the job and fit the same way.
FrankieCarbone
May 17, 2012 04:00 PM
SpecR
Feb 27, 2010 07:57 PM
my98gtvr4
Oct 22, 2008 01:16 PM
Glocker23
Nov 5, 2006 04:26 PM
cjbettis
Feb 22, 2006 11:25 AM
