Tube under the tank
Tube under the tank
Sorry for the pesky posts but the bike is new to me and I want to learn. I lifted my tank today and a bunch of nasty water came spilling out of a tube that runs from the middle of under the tank to under the bike. What is that tube for? I also noticed that the tube is kinked when the tank is down, is this supposed to be that way?, or should it be replaced?
I'm attempting to put on a new chain and sprockets tomorrow, wish me luck.
Thanks, Matt
Thanks, Matt
Guest
Posts: n/a
That would prolly be the fuel tank breather , and no it should not be either kinked or filled with chitty water ..
What you saw come from it was prolly allot of built up condensation from the tank that has not been able to get away ...
....most of the time when it gets blocked for any reason , the bike has trouble running shortly after starting ..
Male sure when you re fit the tank that the line don't get squished !! ...
Thanks for the replies!! I will replace the tube when I get a chance for it is rock hard.
As for the chain and sprocket, I replcaed the sprockets but the chain needs to be shortened and I have to borrow a chain breaker from a buddy to finish the job. The bearings were A ok upon inspection.
Matt
Matt
busyychild
08-03-2007 07:13 PM
