Throttle adjustment
Throttle adjustment
Gday ladies and gents, it’s been I while since I’ve posted. Anyway I hope you doing well and living life and riding fast.
Well im wondering if anyone can help with the best way to get rid of the play in my throttle as it’s just not cool/safe the way it is. I have about 5-6 mm of travel from throttle off to throttle opening. And help on the best/easiest way would be greatly appreciated cheers people. Keep the rubber side down
If it just needs a minor adjustment, you can use the upper adjuster at the handlebar. Just loosen the locknut and turn the adjuster. If it doesn't adjust far enough, you'll have to prop up the tank and make the adjustment at the lower adjuster between the carbs. It should the rearmost of the two cables
Hope that helps
Hope that helps
